Ana içeriğe geç
iHome IH11 AC Power Adapter Replacement
Neye ihtiyacın var
  1. iHome IH11 AC Power Adapter Replacement, Outer Case: adım 1, 1 resimden 1.
    • Unscrew the two 9.0 mm screws with the Phillips #1.
    • Remove the translucent bottom plastic piece.
    FixBot'a Sor
    Yorum Ekle
  2. iHome IH11 AC Power Adapter Replacement: adım 2, 2 resimden 1. iHome IH11 AC Power Adapter Replacement: adım 2, 2 resimden 2.
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires attached to the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. iHome IH11 AC Power Adapter Replacement: adım 3, 1 resimden 1.
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
    FixBot'a Sor
    Yorum Ekle
  4. iHome IH11 AC Power Adapter Replacement, Motherboard: adım 4, 2 resimden 1. iHome IH11 AC Power Adapter Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
    • Slide the motherboard gently out.
    FixBot'a Sor
    Yorum Ekle
  5. iHome IH11 AC Power Adapter Replacement: adım 5, 1 resimden 1.
    • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
    • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
    FixBot'a Sor
    Yorum Ekle
  6. iHome IH11 AC Power Adapter Replacement: adım 6, 2 resimden 1. iHome IH11 AC Power Adapter Replacement: adım 6, 2 resimden 2.
    • Unsolder the main connections holding the AC adapter to the circuit board.
    • Solder new adapter in same position with same connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nick Knowles
21 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G9
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 999
