Ana içeriğe geç
iHome IH11 Control Buttons Replacement
Neye ihtiyacın var
  1. iHome IH11 Control Buttons Replacement, Outer Case: adım 1, 1 resimden 1.
    • Unscrew the two 9.0 mm screws with the Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Control Buttons Replacement: adım 2, 2 resimden 1. iHome IH11 Control Buttons Replacement: adım 2, 2 resimden 2.
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two screws on the bottom.
  3. iHome IH11 Control Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the two 9mm screws from the top of the iHome with a Phillips #1 Screwdriver.
  4. iHome IH11 Control Buttons Replacement: adım 4, 1 resimden 1.
    • Pop the dock connector out of the iHome and gently pull the white plastic plug from the dock connector.
  5. iHome IH11 Control Buttons Replacement: adım 5, 1 resimden 1.
    • Carefully pull apart the device.
    • Remove the four screws that hold the circuit board for the buttons.
  6. iHome IH11 Control Buttons Replacement: adım 6, 1 resimden 1.
    • Desolder the four connections for the broken button.
    • Solder the new button in the place of the old one.
    • For more information about soldering, refer to the soldering device page. Soldering Skills
Sonuç
Bir başkası bu kılavuzu tamamladı.
Courtney Steinberg
35 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G9
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 330
