Ana içeriğe geç
iHome IH11 Dock Connector Replacement
Neye ihtiyacın var
  1. iHome IH11 Dock Connector Replacement, Dock Connector: adım 1, 1 resimden 1.
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: adım 2, 2 resimden 1. iHome IH11 Dock Connector Replacement: adım 2, 2 resimden 2.
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: adım 3, 1 resimden 1.
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nick Knowles
21 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G9
5 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Where can I buy a replacement dock connector?
A Ross - Yanıt
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,392
