Ana içeriğe geç
iHome IH11 Main Motherboard Replacement
Neye ihtiyacın var
  1. iHome IH11 Main Motherboard Replacement, Outer Case: adım 1, 1 resimden 1.
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: adım 2, 2 resimden 1. iHome IH11 Main Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: adım 4, 2 resimden 1. iHome IH11 Main Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: adım 5, 1 resimden 1.
    • Solder each wire to corresponding input on the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Courtney Steinberg
35 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G9
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 370
