Ana içeriğe geç
iHome iAVS16 LCD (Display) Replacement
Neye ihtiyacın var
  1. iHome iAVS16 LCD (Display) Replacement, Power Board: adım 1, 3 resimden 1. iHome iAVS16 LCD (Display) Replacement, Power Board: adım 1, 3 resimden 2. iHome iAVS16 LCD (Display) Replacement, Power Board: adım 1, 3 resimden 3.
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
    FixBot'a Sor
    Yorum Ekle
  2. iHome iAVS16 LCD (Display) Replacement: adım 2, 3 resimden 1. iHome iAVS16 LCD (Display) Replacement: adım 2, 3 resimden 2. iHome iAVS16 LCD (Display) Replacement: adım 2, 3 resimden 3.
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
    FixBot'a Sor
    Yorum Ekle
  3. iHome iAVS16 LCD (Display) Replacement: adım 3, 2 resimden 1. iHome iAVS16 LCD (Display) Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
    FixBot'a Sor
    Yorum Ekle
  4. iHome iAVS16 LCD (Display) Replacement: adım 4, 3 resimden 1. iHome iAVS16 LCD (Display) Replacement: adım 4, 3 resimden 2. iHome iAVS16 LCD (Display) Replacement: adım 4, 3 resimden 3.
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  5. iHome iAVS16 LCD (Display) Replacement, LCD (Display): adım 5, 3 resimden 1. iHome iAVS16 LCD (Display) Replacement, LCD (Display): adım 5, 3 resimden 2. iHome iAVS16 LCD (Display) Replacement, LCD (Display): adım 5, 3 resimden 3.
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
    FixBot'a Sor
    Yorum Ekle
  6. iHome iAVS16 LCD (Display) Replacement: adım 6, 1 resimden 1.
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
    FixBot'a Sor
    Yorum Ekle
  7. iHome iAVS16 LCD (Display) Replacement: adım 7, 3 resimden 1. iHome iAVS16 LCD (Display) Replacement: adım 7, 3 resimden 2. iHome iAVS16 LCD (Display) Replacement: adım 7, 3 resimden 3.
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Marco Sousa
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G7
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 418
