Ana içeriğe geç
iHome iAVS16 Motherboard Replacement
Neye ihtiyacın var
  1. iHome iAVS16 Motherboard Replacement, Power Board: adım 1, 3 resimden 1. iHome iAVS16 Motherboard Replacement, Power Board: adım 1, 3 resimden 2. iHome iAVS16 Motherboard Replacement, Power Board: adım 1, 3 resimden 3.
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Motherboard Replacement: adım 2, 3 resimden 1. iHome iAVS16 Motherboard Replacement: adım 2, 3 resimden 2. iHome iAVS16 Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Motherboard Replacement: adım 3, 2 resimden 1. iHome iAVS16 Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Motherboard Replacement: adım 4, 3 resimden 1. iHome iAVS16 Motherboard Replacement: adım 4, 3 resimden 2. iHome iAVS16 Motherboard Replacement: adım 4, 3 resimden 3.
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 Motherboard Replacement, LCD (Display): adım 5, 3 resimden 1. iHome iAVS16 Motherboard Replacement, LCD (Display): adım 5, 3 resimden 2. iHome iAVS16 Motherboard Replacement, LCD (Display): adım 5, 3 resimden 3.
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 Motherboard Replacement: adım 7, 3 resimden 1. iHome iAVS16 Motherboard Replacement: adım 7, 3 resimden 2. iHome iAVS16 Motherboard Replacement: adım 7, 3 resimden 3.
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
  8. iHome iAVS16 Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Flip up the back of the device encasing the motherboard.
  9. iHome iAVS16 Motherboard Replacement: adım 9, 3 resimden 1. iHome iAVS16 Motherboard Replacement: adım 9, 3 resimden 2. iHome iAVS16 Motherboard Replacement: adım 9, 3 resimden 3.
    Satın Al
    • Using tweezers, unplug the white, red, and blue connectors from the motherboard by pulling each out.
  10. iHome iAVS16 Motherboard Replacement: adım 10, 1 resimden 1.
    • Carefully unplug the ribbon cable, making sure not to rip it.
Sonuç
James Hoye
97 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G7
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 227
