Ana içeriğe geç
iHome iAVS16 Power Board Replacement
Neye ihtiyacın var
  1. iHome iAVS16 Power Board Replacement, Power Board: adım 1, 3 resimden 1. iHome iAVS16 Power Board Replacement, Power Board: adım 1, 3 resimden 2. iHome iAVS16 Power Board Replacement, Power Board: adım 1, 3 resimden 3.
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Power Board Replacement: adım 2, 3 resimden 1. iHome iAVS16 Power Board Replacement: adım 2, 3 resimden 2. iHome iAVS16 Power Board Replacement: adım 2, 3 resimden 3.
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Power Board Replacement: adım 3, 2 resimden 1. iHome iAVS16 Power Board Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Power Board Replacement: adım 4, 3 resimden 1. iHome iAVS16 Power Board Replacement: adım 4, 3 resimden 2. iHome iAVS16 Power Board Replacement: adım 4, 3 resimden 3.
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
Sonuç
Ashley Famularo
181 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G7
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 123
