Ana içeriğe geç
iHome iBT16 Base Plate Replacement
Neye ihtiyacın var
  1. iHome iBT16 Base Plate Replacement, Base Plate: adım 1, 2 resimden 1. iHome iBT16 Base Plate Replacement, Base Plate: adım 1, 2 resimden 2.
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Base Plate Replacement: adım 2, 2 resimden 1. iHome iBT16 Base Plate Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
Sonuç
Ryan Edwards
331 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G6
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 209
