Ana içeriğe geç
iHome iBT230 Motherboard Replacement
Neye ihtiyacın var
    1. iHome iBT230 Motherboard  Replacement, Motherboard: adım 1, 1 resimden 1.
      • Remove the four 5.5 mm Phillips Head #00 screws from the bottom palate of the iBT230.
      FixBot'a Sor
      Yorum Ekle
    2. iHome iBT230 Motherboard  Replacement: adım 2, 2 resimden 1. iHome iBT230 Motherboard  Replacement: adım 2, 2 resimden 2.
      • Grip the top of the iBT230 by placing your thumb on the back portion, where the USB port is located. Pull up, and you should notice various different colored wires, connected to the Main Motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. iHome iBT230 Motherboard  Replacement: adım 3, 3 resimden 1. iHome iBT230 Motherboard  Replacement: adım 3, 3 resimden 2. iHome iBT230 Motherboard  Replacement: adım 3, 3 resimden 3.
      • Unplug the connectors from all sides of the iBT230, and unplug the wire connected to the screen.
      • Make sure to note which wire goes where, you don't want to re-solder the wires into the incorrect ports!
      FixBot'a Sor
      Yorum Ekle
    4. iHome iBT230 Motherboard  Replacement: adım 4, 2 resimden 1. iHome iBT230 Motherboard  Replacement: adım 4, 2 resimden 2.
      • On the bottom component where the green Main Motherboard is located, remove the two 5.5 mm Phillips #00 screws.
      • The old Motherboard will come free from the bottom of the iBT230.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bilal Siddiqui
376 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G6, Liner Spring 2017 UW Tacoma, Team S3-G6, Liner Spring 2017 üyesi
UWT-LINER-S17S3G6
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 983
