Ana içeriğe geç
iHome iBT84 Light Fixture Replacement
Neye ihtiyacın var
  1. iHome iBT84 Light Fixture Replacement, Motherboard: adım 1, 2 resimden 1. iHome iBT84 Light Fixture Replacement, Motherboard: adım 1, 2 resimden 2.
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Light Fixture Replacement: adım 2, 2 resimden 1. iHome iBT84 Light Fixture Replacement: adım 2, 2 resimden 2.
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Light Fixture Replacement: adım 3, 3 resimden 1. iHome iBT84 Light Fixture Replacement: adım 3, 3 resimden 2. iHome iBT84 Light Fixture Replacement: adım 3, 3 resimden 3.
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Light Fixture Replacement: adım 4, 1 resimden 1.
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
  5. iHome iBT84 Light Fixture Replacement, Light Fixture: adım 5, 1 resimden 1.
    • Use the screwdriver to unscrew the screws on the left and right sides.
  6. iHome iBT84 Light Fixture Replacement: adım 6, 1 resimden 1.
    • Once unscrewed, use the metal spudge to lift the base of the light fixture.
  7. iHome iBT84 Light Fixture Replacement: adım 7, 2 resimden 1. iHome iBT84 Light Fixture Replacement: adım 7, 2 resimden 2.
    • Lift the base of the light fixture out with the lights.
    • Be careful. The light fixture's can be easily bent.
  8. iHome iBT84 Light Fixture Replacement: adım 8, 2 resimden 1. iHome iBT84 Light Fixture Replacement: adım 8, 2 resimden 2.
    • Pull gently on the individual light fixture that needs to be replaced.
    • Place new individual LED light strip.
Sonuç
Joshua Lopez
101 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 569
