Ana içeriğe geç
iHome iH27B Power Connector Replacement
Neye ihtiyacın var
  1. iHome iH27B Power Connector Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Power Connector Replacement: adım 2, 3 resimden 1. iHome iH27B Power Connector Replacement: adım 2, 3 resimden 2. iHome iH27B Power Connector Replacement: adım 2, 3 resimden 3.
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Power Connector Replacement: adım 3, 1 resimden 1.
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Power Connector Replacement: adım 4, 1 resimden 1.
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Power Connector Replacement: adım 5, 1 resimden 1.
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Power Connector Replacement, Power Connector: adım 6, 2 resimden 1. iHome iH27B Power Connector Replacement, Power Connector: adım 6, 2 resimden 2.
    • Firmly grasp the power connector, which is the plastic rectangular piece with the white and black wires connected to it.
    • Pull upwards and dislodge the connector.
  7. iHome iH27B Power Connector Replacement: adım 7, 1 resimden 1.
    • Using the scissors on your wire strippers, cut the connecting wires.
    • Using your wire strippers, remove about 1/4 " of the plastic tubing surrounding the end of your exposed wire, careful to not damage the wires.
    • Using a wire-nut or electrician's tape, connect the wires of the replacement power connector to your exposed wires. Connect white wire to white, and black to black.
Sonuç
John Kraemer
76 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G21
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 2,177
