Ana içeriğe geç
iHome iH27B iPod Adapter Replacement
Neye ihtiyacın var
  1. iHome iH27B iPod Adapter Replacement, Adapter: adım 1, 1 resimden 1.
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
    FixBot'a Sor
    Yorum Ekle
  2. iHome iH27B iPod Adapter Replacement: adım 2, 1 resimden 1.
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
    FixBot'a Sor
    Yorum Ekle
  3. iHome iH27B iPod Adapter Replacement: adım 3, 3 resimden 1. iHome iH27B iPod Adapter Replacement: adım 3, 3 resimden 2. iHome iH27B iPod Adapter Replacement: adım 3, 3 resimden 3.
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
    FixBot'a Sor
    Yorum Ekle
  4. iHome iH27B iPod Adapter Replacement: adım 4, 2 resimden 1. iHome iH27B iPod Adapter Replacement: adım 4, 2 resimden 2.
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
    FixBot'a Sor
    Yorum Ekle
  5. iHome iH27B iPod Adapter Replacement: adım 5, 1 resimden 1.
    • Pull out the adapter, and replace it with the new one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Kraemer
76 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G21
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 55
Her zaman: 2,739
