Ana içeriğe geç
iHome iH27B iPod Adapter Replacement
Neye ihtiyacın var
  1. iHome iH27B iPod Adapter Replacement, Adapter: adım 1, 1 resimden 1.
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
  2. iHome iH27B iPod Adapter Replacement: adım 2, 1 resimden 1.
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
  3. iHome iH27B iPod Adapter Replacement: adım 3, 3 resimden 1. iHome iH27B iPod Adapter Replacement: adım 3, 3 resimden 2. iHome iH27B iPod Adapter Replacement: adım 3, 3 resimden 3.
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
  4. iHome iH27B iPod Adapter Replacement: adım 4, 2 resimden 1. iHome iH27B iPod Adapter Replacement: adım 4, 2 resimden 2.
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
  5. iHome iH27B iPod Adapter Replacement: adım 5, 1 resimden 1.
    • Pull out the adapter, and replace it with the new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Kraemer
76 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G21
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 2,391
