Ana içeriğe geç
iHome iH8BR iPod Adapter Replacement
Neye ihtiyacın var
  1. iHome iH8BR iPod Adapter Replacement, Lower Case: adım 1, 3 resimden 1. iHome iH8BR iPod Adapter Replacement, Lower Case: adım 1, 3 resimden 2. iHome iH8BR iPod Adapter Replacement, Lower Case: adım 1, 3 resimden 3.
    • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
    • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
    • Remove the battery cover and the batteries.
  2. iHome iH8BR iPod Adapter Replacement: adım 2, 2 resimden 1. iHome iH8BR iPod Adapter Replacement: adım 2, 2 resimden 2.
    • Slide a spudger under the two front rubber pads to expose two hidden screws.
  3. iHome iH8BR iPod Adapter Replacement: adım 3, 1 resimden 1.
    • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
  4. iHome iH8BR iPod Adapter Replacement: adım 4, 2 resimden 1. iHome iH8BR iPod Adapter Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
    • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
    • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
    • The lower case can now be completely removed from the device!
  5. iHome iH8BR iPod Adapter Replacement, Motherboard Assembly: adım 5, 2 resimden 1. iHome iH8BR iPod Adapter Replacement, Motherboard Assembly: adım 5, 2 resimden 2.
    • Remove the four screws attaching the top of the case to the motherboard:
    • Two 9.5 mm Phillips #2 screws near the speaker grille.
    • Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
    • It is useful to use a screwdriver with a magnetic tip so that the screws don't get lost inside the device.
  6. iHome iH8BR iPod Adapter Replacement: adım 6, 2 resimden 1. iHome iH8BR iPod Adapter Replacement: adım 6, 2 resimden 2.
    • Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
    • Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
    • Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
    • If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
    • Pull the back adapter cover off.
  7. iHome iH8BR iPod Adapter Replacement: adım 7, 2 resimden 1. iHome iH8BR iPod Adapter Replacement: adım 7, 2 resimden 2.
    • Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
    • Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
    • Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
    • One 4.0 mm Phillips #1 screw near the center of the adapter.
    • The iPod adapter should now be separate from the upper casing.
  8. iHome iH8BR iPod Adapter Replacement: adım 8, 3 resimden 1. iHome iH8BR iPod Adapter Replacement: adım 8, 3 resimden 2. iHome iH8BR iPod Adapter Replacement: adım 8, 3 resimden 3.
    • With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown.
    • Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves.
    • Use tweezers to remove the 6 ribbon cables.
  9. iHome iH8BR iPod Adapter Replacement: adım 9, 1 resimden 1.
    • Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
    • You have now separated your iHome's inner workings from its protective case!
  10. iHome iH8BR iPod Adapter Replacement, iPod Adapter: adım 10, 2 resimden 1. iHome iH8BR iPod Adapter Replacement, iPod Adapter: adım 10, 2 resimden 2.
    • Remove the two 1.8 mm Phillips #2 black screws from iPod stand.
    • You can now separate the iPod adapter from its casing!
Sonuç
Bir başkası bu kılavuzu tamamladı.
cfredric
70 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-33, Amido Spring 2013 Cal Poly, Team 12-33, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G33
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 1,448
