Giriş
Is your device's dial sticking or not rotating at all? Access either the tuning or volume dial located on the top of the iHome iH9 using this guide. From there, you can clean the dials or replace them if they are broken.
It is best to do this on a flat surface with plenty of space. This replacement involves removing many screws, so keep track of them to ensure easy reassembly. You can organize the screws by placing them on a magnetic pad immediately upon removal.
Neye ihtiyacın var
Pull the tab towards you and lift up to remove the battery cover.
Remove the two AA batteries.
Unscrew the four 8mm Phillips #2 screws.
Unscrew the six 25mm Phillips #2 screws.
Reinstall the backup battery cover so it is out of the way.
Take the top cover off and flip it so the buttons are face down.
Remove the three 8mm Phillips #0 screws on the back of the dial circuit board.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Could you provide any information about part numbers for the dial and switch? Possibly even where they can be obtained? Thanks!
