Ana içeriğe geç
iHome iM71SC Spring Replacement
Neye ihtiyacın var
    1. iHome iM71SC Spring Replacement, iHome iM71SC Disassembly: adım 1, 1 resimden 1.
      • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
      FixBot'a Sor
      Yorum Ekle
    2. iHome iM71SC Spring Replacement: adım 2, 1 resimden 1.
      • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
      FixBot'a Sor
      Yorum Ekle
    3. iHome iM71SC Spring Replacement: adım 3, 1 resimden 1.
      • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
      FixBot'a Sor
      Yorum Ekle
    4. iHome iM71SC Spring Replacement: adım 4, 1 resimden 1.
      • Remove the now unfastened coverings to expose the internals of the speaker.
      FixBot'a Sor
      Yorum Ekle
    1. iHome iM71SC Spring Replacement, Spring: adım 5, 1 resimden 1.
      • Pry the spring from the speaker housing using the blue plastic pry tool.
      FixBot'a Sor
      Yorum Ekle
    2. iHome iM71SC Spring Replacement: adım 6, 2 resimden 1. iHome iM71SC Spring Replacement: adım 6, 2 resimden 2.
      • Unwind the old spring from the wires.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sarah Brown
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G5, Julie Spring 2017 UMass Dartmouth, Team S7-G5, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G5
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 296
