Ana içeriğe geç
iHome iP1 30-pin Connector Replacement
Neye ihtiyacın var
  1. iHome iP1 30-pin Connector Replacement, Dock Cover: adım 1, 1 resimden 1.
    • Orient the iHome upside down with the speakers facing you.
  2. iHome iP1 30-pin Connector Replacement: adım 2, 1 resimden 1.
    • Remove the two 9.5 mm Phillips #1 screws from the dock cover.
  3. iHome iP1 30-pin Connector Replacement: adım 3, 3 resimden 1. iHome iP1 30-pin Connector Replacement: adım 3, 3 resimden 2. iHome iP1 30-pin Connector Replacement: adım 3, 3 resimden 3.
    • Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
  4. iHome iP1 30-pin Connector Replacement, Back Cover: adım 4, 1 resimden 1.
    • Orient the iHome upside down with the speakers facing away from you.
  5. iHome iP1 30-pin Connector Replacement: adım 5, 2 resimden 1. iHome iP1 30-pin Connector Replacement: adım 5, 2 resimden 2.
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  6. iHome iP1 30-pin Connector Replacement: adım 6, 1 resimden 1.
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  7. iHome iP1 30-pin Connector Replacement, 30-pin Connector: adım 7, 1 resimden 1.
    • Rotate the iHome so that the speakers are facing you.
    • Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
  8. iHome iP1 30-pin Connector Replacement: adım 8, 3 resimden 1. iHome iP1 30-pin Connector Replacement: adım 8, 3 resimden 2. iHome iP1 30-pin Connector Replacement: adım 8, 3 resimden 3.
    • Rotate the iHome so that the speakers are once again facing away from you and the motherboard is still exposed.
    • Unplug the wide red/white/black wire bundle from the lower right-hand corner of the motherboard by pulling it out of their connection.
  9. iHome iP1 30-pin Connector Replacement: adım 9, 3 resimden 1. iHome iP1 30-pin Connector Replacement: adım 9, 3 resimden 2. iHome iP1 30-pin Connector Replacement: adım 9, 3 resimden 3.
    • Rotate the iHome iP1 so that the speakers are now facing you.
    • Remove both of the speaker covers by pulling them off of the faceplate.
  10. iHome iP1 30-pin Connector Replacement: adım 10, 1 resimden 1.
    • Unscrew the twelve 14.5 mm Phillips #2 screws holding the faceplate to the speaker housing. (There are six screws connecting the faceplate to each speaker.)
    • Completing this step will loosen the faceplate enough to pull the bundle of cables attached to the 30-pin connector through a hole in the faceplate, allowing the 30-pin connector to be removed from the iHome.
  11. iHome iP1 30-pin Connector Replacement: adım 11, 3 resimden 1. iHome iP1 30-pin Connector Replacement: adım 11, 3 resimden 2. iHome iP1 30-pin Connector Replacement: adım 11, 3 resimden 3.
    • Detach the 30-pin connector from the dock housing by pushing it through the slot which it sticks out of.
    • Sometimes the 30-pin connector can get stuck in the dock housing, making it difficult to push through. To prevent this, push each side of the 30-pin connector evenly. This step can be accomplished without the use of any additional tools.
    • The command buttons have been shown as removed to show how to detach the 30-pin connector. However, it is not necessary to remove the command buttons in order to remove the 30-pin connector.
  12. iHome iP1 30-pin Connector Replacement: adım 12, 3 resimden 1. iHome iP1 30-pin Connector Replacement: adım 12, 3 resimden 2. iHome iP1 30-pin Connector Replacement: adım 12, 3 resimden 3.
    • Remove the 30-pin connector from the iHome by pulling the bundle of cables attached to it through the center hole in the faceplate.
    • You may have to wiggle the faceplate to be able to pull the bundle of cables through its center hole.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wen Sullivan
518 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-1, Livingston Fall 2016 Cal Poly, Team 20-1, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S20G1
4 Üyeler
7 adet Kılavuz yazıldı
4 Yorum
Where can you buy a new pin connector?
shoreman19 - Yanıt
Where can I buy a new pin connector?
shoreman19 - Yanıt
Edward Voermans - Yanıt
where can i buy new Board
Riyu PC - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 2,504
