Giriş
Use this guide to replace your iHome iP1's damaged or faulty 30-pin connector. This connector is located on the iPod/iPhone dock and is used to connect your Apple device to your iHome iP1.
Neye ihtiyacın var
Rotate the iHome so that the speakers are facing you.
Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
Bir başkası bu kılavuzu tamamladı.
4 Yorum
Where can you buy a new pin connector?
Where can I buy a new pin connector?
