Ana içeriğe geç
iHome iP1 Motherboard Replacement
Neye ihtiyacın var
  1. iHome iP1 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Orient the iHome upside down with the speakers facing away from you.
  2. iHome iP1 Motherboard Replacement: adım 2, 2 resimden 1. iHome iP1 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  3. iHome iP1 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  4. iHome iP1 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. iHome iP1 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
    • The order in which the wire bundles are removed does not matter.
    • You may need to remove some black foam tape in order fully disconnect some of the wires.
  5. iHome iP1 Motherboard Replacement: adım 5, 2 resimden 1. iHome iP1 Motherboard Replacement: adım 5, 2 resimden 2.
    • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
  6. iHome iP1 Motherboard Replacement: adım 6, 2 resimden 1. iHome iP1 Motherboard Replacement: adım 6, 2 resimden 2.
    • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
  7. iHome iP1 Motherboard Replacement: adım 7, 3 resimden 1. iHome iP1 Motherboard Replacement: adım 7, 3 resimden 2. iHome iP1 Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sachin Shenoi
333 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-1, Livingston Fall 2016 Cal Poly, Team 20-1, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S20G1
4 Üyeler
7 adet Kılavuz yazıldı
5 Yorum
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - Yanıt
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - Yanıt
Were you able to buy the motherboard?
Rodrigo -
Rodrigo
rodrigo@r7criacoes.com.br
Rodrigo - Yanıt
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
Riyu PC - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,777
