Ana içeriğe geç
iHome iP21 Display LED Replacement
Neye ihtiyacın var
    1. iHome iP21 Display LED Replacement, Base: adım 1, 3 resimden 1. iHome iP21 Display LED Replacement, Base: adım 1, 3 resimden 2. iHome iP21 Display LED Replacement, Base: adım 1, 3 resimden 3.
      • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
      • Unscrew the four 11mm screws from the base.
      • Pry the base loose using the spudger.
      • Remove the base by hand.
      FixBot'a Sor
      Yorum Ekle
    2. iHome iP21 Display LED Replacement, Housing: adım 2, 2 resimden 1. iHome iP21 Display LED Replacement, Housing: adım 2, 2 resimden 2.
      • Remove the two black 6mm screws connecting the main circuit board to the housing top.
      • Gently pull front housing from the back housing.
      FixBot'a Sor
      Yorum Ekle
    1. iHome iP21 Display LED Replacement, Remove Speaker Assembly: adım 3, 1 resimden 1.
      • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
      FixBot'a Sor
      Yorum Ekle
    2. iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: adım 4, 2 resimden 1. iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: adım 4, 2 resimden 2.
      • Lift speaker assembly
      • Remove four 7mm screws to detach speaker from speaker assembly
      FixBot'a Sor
      Yorum Ekle
    1. iHome iP21 Display LED Replacement, Display circuit board: adım 5, 3 resimden 1. iHome iP21 Display LED Replacement, Display circuit board: adım 5, 3 resimden 2. iHome iP21 Display LED Replacement, Display circuit board: adım 5, 3 resimden 3.
      • Remove six 6mm screws from display circuit board.
      • Press black holding clips down and outward to release display circuit board.
      • Lift display circuit board to detach it from the housing.
      FixBot'a Sor
      Yorum Ekle
    2. iHome iP21 Display LED Replacement, Cables: adım 6, 2 resimden 1. iHome iP21 Display LED Replacement, Cables: adım 6, 2 resimden 2.
      • Desolder the solder joints connecting the grounding cable to the display circuit board.
      • Remove glue from the ribbon cables with your fingers. Grasp and pull the glue to remove it from the circuit board.
      • Desolder the solder joints connecting the three ribbon cables to the back of the display circuit board.
      • Desolder the solder joints connecting the two grounding cables to the back of the display circuit board.
      • Desolder the solder joints connecting the two grounding cables to the back of the main housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Brandy
601 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 552
