Ana içeriğe geç
iHome iP21 Docking Station Pin Replacement
Neye ihtiyacın var
  1. iHome iP21 Docking Station Pin Replacement, Base: adım 1, 3 resimden 1. iHome iP21 Docking Station Pin Replacement, Base: adım 1, 3 resimden 2. iHome iP21 Docking Station Pin Replacement, Base: adım 1, 3 resimden 3.
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Docking Station Pin Replacement, Housing: adım 2, 2 resimden 1. iHome iP21 Docking Station Pin Replacement, Housing: adım 2, 2 resimden 2.
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Docking Station Pin Replacement, 30-pin docking mount: adım 3, 1 resimden 1.
    • Locate the 30-pin docking mount on the iP21. The 30-pin docking mount is visible on top of the iP21.
  4. iHome iP21 Docking Station Pin Replacement, Protective cover: adım 4, 2 resimden 1. iHome iP21 Docking Station Pin Replacement, Protective cover: adım 4, 2 resimden 2.
    • Remove the four 4mm screws from the protective cover using the iFixit Phillips #1 bit
  5. iHome iP21 Docking Station Pin Replacement, Ribbon cables: adım 5, 3 resimden 1. iHome iP21 Docking Station Pin Replacement, Ribbon cables: adım 5, 3 resimden 2. iHome iP21 Docking Station Pin Replacement, Ribbon cables: adım 5, 3 resimden 3.
    • Grasp plastic cable connector ends
    • Remove the mini circuit board with 30-pin mounting dock from the two black plastic pegs.
    • Rock gently back and forth and pull to detach mini circuit board with 30-pin mounting dock attached.
Sonuç
Brandy
601 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 725
