Ana içeriğe geç
iHome iP21 Motherboard Replacement
Neye ihtiyacın var
  1. iHome iP21 Motherboard Replacement, Base: adım 1, 3 resimden 1. iHome iP21 Motherboard Replacement, Base: adım 1, 3 resimden 2. iHome iP21 Motherboard Replacement, Base: adım 1, 3 resimden 3.
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Motherboard Replacement, Housing: adım 2, 2 resimden 1. iHome iP21 Motherboard Replacement, Housing: adım 2, 2 resimden 2.
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Motherboard Replacement, Circuit board: adım 3, 1 resimden 1.
    • Follow the prerequisite guide to remove the main housing.
  4. iHome iP21 Motherboard Replacement, Circuit board mount: adım 4, 1 resimden 1.
    • Remove the two 7mm screws from the circuit board
  5. iHome iP21 Motherboard Replacement, Mounting Bracket: adım 5, 1 resimden 1.
    • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
  6. iHome iP21 Motherboard Replacement, Cables: adım 6, 3 resimden 1. iHome iP21 Motherboard Replacement, Cables: adım 6, 3 resimden 2. iHome iP21 Motherboard Replacement, Cables: adım 6, 3 resimden 3.
    • Peel the glue from each of the three ribbon cable connections.
    • Remove the solder joints from the back of each ribbon cable.
    • Remove the ground wires by removing the solder joints on the back of the housing.
  7. iHome iP21 Motherboard Replacement, Detach cables from circuit board: adım 7, 3 resimden 1. iHome iP21 Motherboard Replacement, Detach cables from circuit board: adım 7, 3 resimden 2. iHome iP21 Motherboard Replacement, Detach cables from circuit board: adım 7, 3 resimden 3.
    • Remove glue from 3 ribbon cables from circuit board using fingers
    • Detach speaker cables from circuit board with soldering iron
    • Remove 3 ribbon cables with soldering iron
Sonuç
Brandy
601 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 274
