Ana içeriğe geç
iHome iP21 Speaker Replacement
Neye ihtiyacın var
  1. iHome iP21 Speaker Replacement, Base: adım 1, 3 resimden 1. iHome iP21 Speaker Replacement, Base: adım 1, 3 resimden 2. iHome iP21 Speaker Replacement, Base: adım 1, 3 resimden 3.
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Speaker Replacement, Housing: adım 2, 2 resimden 1. iHome iP21 Speaker Replacement, Housing: adım 2, 2 resimden 2.
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Speaker Replacement, Remove Speaker Assembly: adım 3, 1 resimden 1.
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  4. iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: adım 4, 2 resimden 1. iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: adım 4, 2 resimden 2.
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
Sonuç
Brandy
601 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 197
