Ana içeriğe geç
iHome iPL8 Buttons Replacement
Neye ihtiyacın var
    1. iHome iPL8  Buttons Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      FixBot'a Sor
      Yorum Ekle
    2. iHome iPL8  Buttons Replacement: adım 2, 1 resimden 1.
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      FixBot'a Sor
      Yorum Ekle
    3. iHome iPL8  Buttons Replacement: adım 3, 1 resimden 1.
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      FixBot'a Sor
      Yorum Ekle
    4. iHome iPL8  Buttons Replacement: adım 4, 2 resimden 1. iHome iPL8  Buttons Replacement: adım 4, 2 resimden 2.
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      FixBot'a Sor
      Yorum Ekle
    1. iHome iPL8  Buttons Replacement, Lightning Connector: adım 5, 1 resimden 1.
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      FixBot'a Sor
      Yorum Ekle
    2. iHome iPL8  Buttons Replacement: adım 6, 1 resimden 1.
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      FixBot'a Sor
      Yorum Ekle
    3. iHome iPL8  Buttons Replacement: adım 7, 2 resimden 1. iHome iPL8  Buttons Replacement: adım 7, 2 resimden 2.
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      FixBot'a Sor
      Yorum Ekle
    4. iHome iPL8  Buttons Replacement: adım 8, 2 resimden 1. iHome iPL8  Buttons Replacement: adım 8, 2 resimden 2.
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      FixBot'a Sor
      Yorum Ekle
    5. iHome iPL8  Buttons Replacement: adım 9, 3 resimden 1. iHome iPL8  Buttons Replacement: adım 9, 3 resimden 2. iHome iPL8  Buttons Replacement: adım 9, 3 resimden 3.
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      FixBot'a Sor
      Yorum Ekle
    1. iHome iPL8  Buttons Replacement, Buttons: adım 10, 3 resimden 1. iHome iPL8  Buttons Replacement, Buttons: adım 10, 3 resimden 2. iHome iPL8  Buttons Replacement, Buttons: adım 10, 3 resimden 3.
      • Locate the light brown, rectangular button board. Remove the five 2.5 mm Phillips #1 screws, four along the perimeter and one in the center.
      • Remove the brown button board.
      • There is a foam sheet underneath the button board. Use your hand to take it off and put it aside.
      FixBot'a Sor
      Yorum Ekle
    2. iHome iPL8  Buttons Replacement: adım 11, 2 resimden 1. iHome iPL8  Buttons Replacement: adım 11, 2 resimden 2.
      • There are two rows of buttons clipped on to the small, circular, black columns.
      • Gently unclip the two rows of buttons and remove them.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chen Zhong
569 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S18-G5, Lore Winter 2019 UC Davis, Team S18-G5, Lore Winter 2019 üyesi
UCD-LORE-W19S18G5
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 519
