Ana içeriğe geç
iLive IKBC384S Motherboard Replacement
Neye ihtiyacın var
  1. iLive IKBC384S Motherboard Replacement, Top Cover: adım 1, 2 resimden 1. iLive IKBC384S Motherboard Replacement, Top Cover: adım 1, 2 resimden 2.
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: adım 2, 2 resimden 1. iLive IKBC384S Motherboard Replacement: adım 2, 2 resimden 2.
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: adım 3, 2 resimden 1. iLive IKBC384S Motherboard Replacement: adım 3, 2 resimden 2.
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: adım 5, 2 resimden 1. iLive IKBC384S Motherboard Replacement: adım 5, 2 resimden 2.
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: adım 6, 1 resimden 1.
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: adım 7, 1 resimden 1.
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
Sonuç
Tracy Walts
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 273
