Giriş
You are going to replace the motherboard simply by unscrewing a few screws and then removing the motherboard from the device.
Neye ihtiyacın var
Make sure you remove all seven 3 mm screws before proceeding to the next step.
After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
Neredeyse bitti!
Sonuç
