Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
本指南将帮助你更换/升级硬盘。
Neye ihtiyacın var
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
将两个大吸力吸盘分别吸附在玻璃面板的左右上角。
然后将拉环扶住,接着抬起拉环,使之与另外一个拉环平行。(如图三)
[1]: 译者注:不必非使用蒸馏水,也可以使用饮用纯净水。
将您的设备,遵循这些指示,逆向重组。
将您的设备,遵循这些指示,逆向重组。
341 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
63 Yorum
Note that if you are replacing the hard drive with a non-Apple hard drive, then you will have problems with the fan running full speed constantly (see http://blog.macsales.com/10206-further-e...). Basically, you'll need to either install a $30 piece of software to control the fans or short out some wires.
You don´t need to short out the wires, just install the free SSD FAN CONTROL app from EXIRION.NET und you´ll be fine :D
remember after the glass, to get the aluminum front off, remove the bay for the memory upgrade on the bottom first before you remove the torx screws ans lift to access the bottom case (Between step 2 and 3)
I'm looking to replace my 3.5" HDD in my iMac (mid-2011) with a 2.5" SSD. Will I need an adapter for this?
Absolutly. You can buy a official one on the Apple Store. I reccommend the dual-drive (HDD & SDD) tho.
