Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Giriş
拆卸 2012 晚期 iMac上的显示屏需要用专门的iMac开箱工具切割粘合剂。当你完成了修复后,你需要根据粘胶指南来擦除上面的残留胶然后使用双面胶替换。
Neye ihtiyacın var
Videoya Genel Bakış
Bu adımda kullanılan alet:iMac Intel 27" Cardboard Service Wedge$4.99
如果铰链可以自由移动,iMac就会失去平衡,难以开展工作。修理时可以让iMac躺下,但使用iMac维修楔子会更快更容易。
如果你使用的是 iFixit纸板服务楔子,请按照 装配说明将其组装起来。
要重新组装你的设备,请按照这些说明逆向操作,并使用我们的胶条指南来重新安装显示玻璃。
把你的电子垃圾送到R2或e-Stewards认证的回收商那里。
维修没有按计划进行?尝试一些基本的故障排除,或向我们的问答社区寻求帮助。
61 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
96%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
20 Yorum
…thanks, but i have a crack on the screen as i was lifting it up. after reconnecting, there where lines on the display. what should i do.?
Something you may want to include for anyone replacing their damaged screen with a new one:
The replacement screens from LG more often DO NOT come with the thermal sensor attached, which means if you replace the screen without transferring the thermal sensor from the old LCD module, the computer will go absolutely insane, rendering it unusable.
This means re-opening the iMac and destroying the brand new adhesive strips. Because I had no idea this sensor existed, much panic ensued before I was forced to rip everything apart again and ultimately securing it closed with packing tape while I waited for the new adhesive strips to arrive in the mail....Not to mention the computer belongs to a client who lives 3 hours outside of the city.
Sorry, could you help me? What thermal sensor?! Could you explain?
See the thin twisted black wire on the back of the display in this photo? The one that ends in a small piece of black tape:
https://d3nevzfk7ii3be.cloudfront.net/ig...
that piece of tape covers the tiny thermal sensor at the end of that wire. It is not included as part of the new display, and must be transferred from the old display or your computer will turn into a nightmare.
But this is for model emc2546 too? And how you can transfer thermal sensor? Thank You!!!!
