Ana içeriğe geç
iMac 2012-2017 SSD Upgrade (IcyDock)
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. iMac 2012-2017 SSD Upgrade (IcyDock), SSD (2012-2017 IcyDock): adım 1, 3 resimden 1. iMac 2012-2017 SSD Upgrade (IcyDock), SSD (2012-2017 IcyDock): adım 1, 3 resimden 2. iMac 2012-2017 SSD Upgrade (IcyDock), SSD (2012-2017 IcyDock): adım 1, 3 resimden 3.
    • Only follow the next 8 steps if you are replacing your hard drive with an SSD kit.
    • Depress the enclosure's front plate latch with your finger. While holding the latch down, swing the plate out.
    • Remove the front plate.
  2. iMac 2012-2017 SSD Upgrade (IcyDock): adım 2, 3 resimden 1. iMac 2012-2017 SSD Upgrade (IcyDock): adım 2, 3 resimden 2. iMac 2012-2017 SSD Upgrade (IcyDock): adım 2, 3 resimden 3.
    • Line up the small SATA connector so that the short side on the SSD connector matches the short side on the enclosure connector.
    • Slide the drive in through the front of the enclosure until the SATA connector is fully seated.
    • The SSD connects with the enclosure in only one way. If the connectors are not lining up, rotate the SSD and try again.
  3. iMac 2012-2017 SSD Upgrade (IcyDock): adım 3, 2 resimden 1. iMac 2012-2017 SSD Upgrade (IcyDock): adım 3, 2 resimden 2.
    • You may optionally install two Philips #1 screws that came with the enclosure kit to secure the SSD in the enclosure.
    • Replace the front plate.
  4. iMac 2012-2017 SSD Upgrade (IcyDock): adım 4, 2 resimden 1. iMac 2012-2017 SSD Upgrade (IcyDock): adım 4, 2 resimden 2.
    • Plug the included sensor-enabled SATA cable into the enclosure's port.
    • Line up the narrow side of the cable connector with the narrow side of the enclosure connector. The cable is keyed to connect in only one way. If you can't connect the cable, rotate it 180°, and try again.
  5. iMac 2012-2017 SSD Upgrade (IcyDock): adım 5, 3 resimden 1. iMac 2012-2017 SSD Upgrade (IcyDock): adım 5, 3 resimden 2. iMac 2012-2017 SSD Upgrade (IcyDock): adım 5, 3 resimden 3.
    • Peel the backing off of the adhesive back of the small temperature sensor board.
    • Adhere the temperature sensor board to an exposed, metal area of the surface of the SSD, as close as possible to the SATA connector.
    • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  6. iMac 2012-2017 SSD Upgrade (IcyDock): adım 6, 1 resimden 1.
    • Install the mounting pins from the old hard drive onto the sides of the enclosure.
    • The holes on the enclosure may not be threaded, so screwing the mounting pins into them may require extra effort. Take your time and screw them in slowly, making sure they go in straight.
  7. iMac 2012-2017 SSD Upgrade (IcyDock): adım 7, 2 resimden 1. iMac 2012-2017 SSD Upgrade (IcyDock): adım 7, 2 resimden 2.
    • Attach any mounting brackets removed from the old hard drive onto the enclosure.
  8. iMac 2012-2017 SSD Upgrade (IcyDock): adım 8, 2 resimden 1. iMac 2012-2017 SSD Upgrade (IcyDock): adım 8, 2 resimden 2.
    • Attach the iMac's SATA-combo cable to the new temperature-capable SATA-combo cable.
    • Route the SATA cables where they will not interfere with any other components.
    • Try to keep the cables free from any sharp bends and route them such that they are not pinched.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
309.619 İtibar
701 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.610 adet Kılavuz yazıldı
3Kılavuz Yorumları
I love the guide~ it is super easy to follow. My computer is not recognizing the disk and I can’t figure out why. I feel like I missed something in reassembly. Any suggestions? Common errors?
Julie Cain - Yanıt
Hi Julie!
Was the new drive formatted before you installed it? You can try to boot the iMac in recovery mode and reinstall the OS from there. If that doesn’t work, please post your question on our Answers forum and someone may be able to help you out!
Arthur Shi -
when doing internet recovery First run the disk utility and Format it using mac journal, then continue to install the new disk will be visible.
SreckoVuka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 37
Son 30 gün: 201
Her zaman: 14,620
