Ana içeriğe geç
Giriş
Upgrade your RAM DIMM Module for more memory.
Parçalar
Hiçbir parça belirtilmedi.
  1. Place the computer monitor face down on a safe, harmless surface. Using a  Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Remove the metal plate from bottom of the iMac G4.
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  4. Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM. These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Ryan Kozak
1.235 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-32, Amido Fall 2011 Cal Poly, Team 5-32, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G32
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Canadaram - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 23
Her zaman: 4,650
