Giriş
Upgrade your RAM DIMM Module for more memory.
Neye ihtiyacın var
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
10 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Thanks For catching this Typo! :-)
