Giriş
Upgrade your hard drive for an instant increase in storage space.
Neye ihtiyacın var
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor.
Insert the flat end of a spudger between the SATA power cable connector and the body of the hard drive.
Twist the spudger counter-clockwise to slightly separate the SATA power cable connector from its socket on the hard drive.
Pull the SATA power cable connector away from the hard drive.
Remove the two T10 Torx screws from both sides of the hard drive (four screws total).
140 farklı kişi bu kılavuzu tamamladı.
5 Yorum
I can't imagine why this disassembly is called "moderate." This has to be one of the easiest Macs to open up and gain access. Interestingly, the very next model, the 1144, is one of the most difficult and painful macs (that I know) to open up for access to the most rudimentary parts (drive and memory). The designers of the 1144+ iMacs should all be taken outside and shot!
Maybe the Quadra 700 is easier - no tools required! Or the G4 and G5 towers. Dunno about the later ones...
Awesome, thanks for helping me breathe life back into my G5, it's going to become the band computer for storing videos/recordings, as well as some mastering and whatnot.
Thank you. This was fast and without pains. Now I will be able now to recover the information from a computer that did not worked at all.
This was great in helping me resuscitate my old iMac G5 and upgrade it in the process! Part of my searching for assistance revolved around what to do with the thermal sensor (mine was attached to the dead hard drive itself rather than the hard drive bracket). Luckily for me, your clear photos helped me determine I could simply pry up the thermal sensor and reattach it elsewhere (like to the hard drive bracket as depicted). Thanks!
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - Yanıt
The two outer screws each drive a locking bar that engage tabs on the rear panel.
They definitely need to be unscrewed.
Dale Stanbrough -
That chick MJ is sexy!!!!!
djmadcracker - Yanıt
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - Yanıt
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - Yanıt
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - Yanıt
These are the easiest way to resolve the Wireless connectivity at my home. Thanks ifixit for sharing this.
Geek Squad - Yanıt
