Ana içeriğe geç
iMac G5 17" Model A1058 PRAM Battery Replacement
Neye ihtiyacın var
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, Rear Panel: adım 1, 1 resimden 1.
      • Lay the iMac display-side down on a flat surface.
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      FixBot'a Sor
      Yorum Ekle
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: adım 2, 3 resimden 1. iMac G5 17" Model A1058 PRAM Battery Replacement: adım 2, 3 resimden 2. iMac G5 17" Model A1058 PRAM Battery Replacement: adım 2, 3 resimden 3.
      • Lift the rear panel slightly from the bottom edge of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      FixBot'a Sor
      Yorum Ekle
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, AirPort Extreme: adım 3, 1 resimden 1.
      • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
      • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
      FixBot'a Sor
      Yorum Ekle
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: adım 4, 1 resimden 1.
      • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
      • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
      • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
      FixBot'a Sor
      Yorum Ekle
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, PRAM Battery: adım 5, 1 resimden 1.
      • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
      FixBot'a Sor
      Yorum Ekle
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: adım 6, 1 resimden 1.
      • Slightly lift the AirPort bracket off the logic board.
      • De-route the AirPort antenna through the slot in the AirPort bracket.
      FixBot'a Sor
      Yorum Ekle
    3. iMac G5 17" Model A1058 PRAM Battery Replacement: adım 7, 1 resimden 1.
      • Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
      • Do not bend the metal retaining clip up, as it is brittle and will break.
      • Use another spudger to slide the PRAM battery out from under its socket's retaining clip.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 19,544
