Ana içeriğe geç
iMac G5 17" Model A1058 RAM Replacement
Neye ihtiyacın var
    1. iMac G5 17" Model A1058 RAM Replacement, Rear Panel: adım 1, 1 resimden 1.
      • Lay the iMac display-side down on a flat surface.
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      FixBot'a Sor
      Yorum Ekle
    2. iMac G5 17" Model A1058 RAM Replacement: adım 2, 3 resimden 1. iMac G5 17" Model A1058 RAM Replacement: adım 2, 3 resimden 2. iMac G5 17" Model A1058 RAM Replacement: adım 2, 3 resimden 3.
      • Lift the rear panel slightly from the bottom edge of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      FixBot'a Sor
      Yorum Ekle
    1. iMac G5 17" Model A1058 RAM Replacement, RAM: adım 3, 3 resimden 1. iMac G5 17" Model A1058 RAM Replacement, RAM: adım 3, 3 resimden 2. iMac G5 17" Model A1058 RAM Replacement, RAM: adım 3, 3 resimden 3.
      • Rotate each of the two RAM retaining arms away from the RAM chip.
      • Pull the RAM chip straight away from its socket.
      • Repeat this process for the other RAM chip.
      • Be sure the RAM arms are fully rotated away from the RAM socket before reinstalling any RAM chips.
      FixBot'a Sor
      Yorum Ekle
Sonuç
39 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Way too easy. Doubled my RAM in 5 minutes. Computer runs like new again.
Darren Fox - Yanıt Paylaş
Can i get 6 or 8 gigs ram?
frederikchalmer - Yanıt Paylaş
Do both the ram slots have to have ram in them
Gary Wayne - Yanıt Paylaş
When I cut it on the Apple pops up then a colored screen comes up with horizontal lines
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 73
Her zaman: 31,977
