Giriş
Keep processor temperatures down by replacing your broken fans.
Aletler
Parçalar
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
Bir başkası bu kılavuzu tamamladı.
