Giriş
The ins and outs of replacing your DC to DC board.
Neye ihtiyacın var
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Bu adımda kullanılan alet:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Pull the DC power cable connector away from its socket to disconnect it from the DC to DC board.
2 farklı kişi bu kılavuzu tamamladı.
