Ana içeriğe geç
iMac G5 17" Model A1144 IR Board Replacement
Neye ihtiyacın var
  1. iMac G5 17" Model A1144 IR Board Replacement, Access Door: adım 1, 1 resimden 1.
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
  2. iMac G5 17" Model A1144 IR Board Replacement: adım 2, 1 resimden 1.
    • Remove the access door from your iMac.
  3. iMac G5 17" Model A1144 IR Board Replacement, Front Bezel: adım 3, 1 resimden 1.
    • Remove the three T8 Torx screws securing the front bezel to the rear panel.
  4. iMac G5 17" Model A1144 IR Board Replacement: adım 4, 2 resimden 1. iMac G5 17" Model A1144 IR Board Replacement: adım 4, 2 resimden 2.
    • Orient the iMac face-up, on its backside.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 17" Model A1144 IR Board Replacement: adım 5, 1 resimden 1.
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  6. iMac G5 17" Model A1144 IR Board Replacement: adım 6, 3 resimden 1. iMac G5 17" Model A1144 IR Board Replacement: adım 6, 3 resimden 2. iMac G5 17" Model A1144 IR Board Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  7. iMac G5 17" Model A1144 IR Board Replacement: adım 7, 1 resimden 1.
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  8. iMac G5 17" Model A1144 IR Board Replacement: adım 8, 1 resimden 1.
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
  9. iMac G5 17" Model A1144 IR Board Replacement: adım 9, 2 resimden 1. iMac G5 17" Model A1144 IR Board Replacement: adım 9, 2 resimden 2.
    • Disconnect both the camera and microphone cables.
  10. iMac G5 17" Model A1144 IR Board Replacement, IR Board: adım 10, 1 resimden 1.
    • Peel back the aluminum EMI shield up off the lower three edges of the rear case.
    • It is not necessary to peel the EMI shield off the display.
    • We found it helpful to tape the EMI shield up against the display to keep it out of the way.
  11. iMac G5 17" Model A1144 IR Board Replacement: adım 11, 1 resimden 1.
    • Remove the single T6 Torx screw securing the IR board bracket to the logic board.
    • The IR board and cable finger are now free from the logic board and may fall.
  12. iMac G5 17" Model A1144 IR Board Replacement: adım 12, 1 resimden 1.
    • Pull the IR Board cable connector straight away from its socket on the IR board.
  13. iMac G5 17" Model A1144 IR Board Replacement: adım 13, 1 resimden 1.
    • Transfer the two T6 Torx screws and the IR bracket to your new IR board.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 4,258
