Giriş
Replace your broken optical drive fan to keep temperatures down!
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
Lift the optical drive fan off the plastic posts protruding from the rear case.
Bir başkası bu kılavuzu tamamladı.
