Giriş
Is your iMac dead to the world? A fried power supply could be the problem.
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Disconnect the hard drive thermal sensor by pulling the connector away from its socket parallel to the face of the hard drive.
Pull the power supply cable connector away from its socket to disconnect it from the DC to DC board.
15 farklı kişi bu kılavuzu tamamladı.
