Giriş
Is your iMac always mute? Replace your blown out speakers to keep your iMac singing like it should.
Neye ihtiyacın var
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Bu adımda kullanılan alet:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
2 farklı kişi bu kılavuzu tamamladı.
