Giriş
Use this guide to replace the monster 20" LCD housed within your iMac.
Neye ihtiyacın var
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
Remove the following three screws securing the inverter to the chassis:
Two 7.9 mm Phillips.
One 26 mm Phillips.
Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
Remove the two 7.3 mm shouldered Phillips screws securing the display cable connector to the logic board.
18 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Excellent Thank you
Very detailed. Thank you.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - Yanıt
