Giriş
Instantly increase the speed of your iMac by upgrading the RAM.
Neye ihtiyacın var
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
31 farklı kişi bu kılavuzu tamamladı.
2 Yorum
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
Easy as pie, instructions were right to the point, thank you.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - Yanıt
