Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the following two screws:
One 11 mm T10 Torx.
One 10.6 mm T8 Torx.
Disconnect the right fan from the logic board by pulling its connector straight up.
Remove the two 11.6 mm shouldered T8 Torx screws from the right fan.
Lift the fan near its outlet and rotate it toward yourself until its lower bracket clears the edge of the logic board.
Lift the fan out of the chassis.
6 farklı kişi bu kılavuzu tamamladı.
