Parçalar
Hiçbir parça belirtilmedi.
Disconnect the optical drive thermal sensor by pulling its cable toward the left edge of your iMac.
Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
Neredeyse bitti!
Sonuç
