Neye ihtiyacın var
Disconnect the optical drive thermal sensor by pulling its cable toward the left edge of your iMac.
Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
try to release the bracket closest the logic board first. Pressing the bracket down a bit to add clearance between the bracket notch and the frame. The other should be easier to press down on the dvd case whilst pressing the lever.
Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
