Ana içeriğe geç
iMac G5 20" Model A1145 RAM Replacement
Neye ihtiyacın var
    1. iMac G5 20" Model A1145 RAM Replacement, Access Door: adım 1, 1 resimden 1.
      • Orient the iMac face-side down on a table with the bottom edge facing yourself.
      • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
      • The screws are captive in the access door.
      • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
      FixBot'a Sor
      Yorum Ekle
    2. iMac G5 20" Model A1145 RAM Replacement: adım 2, 1 resimden 1.
      • Remove the access door.
      FixBot'a Sor
      Yorum Ekle
    1. iMac G5 20" Model A1145 RAM Replacement, RAM: adım 3, 1 resimden 1.
      • Insert your fingers into the two RAM arms and pull both arms toward yourself to eject the RAM chip.
      FixBot'a Sor
      Yorum Ekle
    2. iMac G5 20" Model A1145 RAM Replacement: adım 4, 1 resimden 1.
      • Slide the RAM chip straight out of its socket.
      • Make sure both RAM arms are fully rotated outward before reinstalling your RAM chip.
      FixBot'a Sor
      Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 60
Her zaman: 21,695
