Giriş
Remove the access door to replace RAM chips and remove your front bezel.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Loosen the two captive Phillips screws securing the access door to the iMac.
Remove the access door from the iMac.
Neredeyse bitti!
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
That is a really, really unnecessarily complex way of fitting a new hard drive. Thanks, but no thanks...
annax - Yanıt
annax, if you can suggest a simpler way we're all ears!
Jake Simmonds - Yanıt
I found this guide to be very useful. The installation was super easy, especially since I've never opened my iMac before. I was able to skip steps 6, 7, 9, 10 and 14. Wish I had one of those long skinny magnetic torx screwdriver's though. I had to use duct tape to hold the screws on the end of the bit for step 12.
I used this opportunity to vacuum out the dust with mini attachments. Much needed after 3 years ;0)
Awesome site!!! Thanks for sharing your knowledge and saving me time and $$$!
Eric Patten - Yanıt
Yes I did it! thanks for this very good manual
Philippe d Anfray - Yanıt
