Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Loosen the two captive Phillips screws securing the access door to the iMac.
Remove the access door from the iMac.
Remove the following four screws:
Three 6 mm T8 Torx.
One 8 mm T8 Torx.
Flip your iMac over and lay it stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the Front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Bu adımda kullanılan alet:Plastic Cards$2.99-
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape(it is ok to toss this) wrapped around the microphone and camera cables.
Remove the two 4.8 mm T6 Torx screws securing the display data cable to the logic board.
Grab the display data cable connector by its black tab and pull it straight up off the logic board.
Inverter cable on 24inch iMac pulls off to the left.
Pull the inverter cable connector straight up off its socket on the logic board.
Peel back the aluminum EMI tape from the two vertical edges of the display.
Bu adımda kullanılan alet:TR10 Torx Security Screwdriver$5.99-
Remove the four 8 mm with 2 mm thick head coarse-thread T10 Torx screws securing the display to the rear case.
Lift the display from its lower edge and pull it toward yourself to peel off the EMI shield attached to its top edge.
De-route the bundle of power supply cables from behind the hard drive bracket.
Pull the hard drive thermal sensor connector away from its socket on the logic board.
Press the hard drive bracket down to free it from the rear case, then rotate the top of the drive toward yourself.
Lift the hard drive off its lower pins and pull it out of the rear case, minding the power supply cables that may get caught.
Insert a spudger between the SATA connectors and twist it to separate the connector from the hard drive.
Disconnect both SATA connectors.
Unplug the power supply cable bundle from the logic board by simultaneously depressing the locking mechanism (toward yourself) with a spudger and pulling the connector away from its socket.
Use a pair of tweezers to pull the AC-in cable out from underneath the chassis.
Disconnect the AC-in cable by simultaneously depressing its locking mechanism and pulling the connector away from its socket.
Remove the four T10 Torx screws securing the power supply to the rear case.
Two 14mm fine-thread screws on the right.
One 14mm coarse-thread screw in lower left corner.
One 20mm coarse-thread screw in upper left corner.
Lift the power supply out of the rear case, minding the AC inlet cable that may get caught on the chassis.
57 farklı kişi bu kılavuzu tamamladı.
5 Yorum
The PSU in the 17” is smaller than shown and has the DC - DC convertor above it.
DC - DC convertor is above the psu in the 17” model and the psu is half the size than that shown.
@jess : Check this out: My iMac will not turn on? – it explains how to read the diagnostic LEDs.
