Ana içeriğe geç
iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement
Neye ihtiyacın var
  1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Access Door: adım 1, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Access Door: adım 1, 2 resimden 2.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Front Bezel: adım 2, 1 resimden 1.
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw (Right side of the RAM slot on 2105)
  3. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 3, 3 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 3, 3 resimden 2. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches. Or use two cards for the additional thickness.
    • If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
  4. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 4, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 4, 2 resimden 2.
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  5. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 5, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 5, 2 resimden 2.
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
  6. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 6, 1 resimden 1.
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  7. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 7, 3 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 7, 3 resimden 2. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 7, 3 resimden 3.
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  8. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Lower EMI Shield: adım 8, 1 resimden 1.
    • Peel up the lower EMI shield from the rear case.
    • It is only necessary to peel the shield up from three sides. Leave it attached to the display.
    • If you happen to rip the EMI shield, use a piece of foil tape to cover the tear.
  9. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 9, 1 resimden 1.
    • Tape the EMI shield to the face of the display to keep it out of the way.
  10. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Display: adım 10, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Display: adım 10, 2 resimden 2.
    • Remove the two 5 mm T6 Torx screws securing the display data cable connector to the logic board.
    • Pull the display data cable connector up off the logic board by its black pull tab.
  11. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 11, 1 resimden 1.
    • Peel back the EMI tape from the two vertical edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  12. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 12, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 12, 2 resimden 2.
    • Allow the lower EMI shield to hang down from the display.
    • Remove the four 7.5 mm T10 Torx screws securing the display to the rear case.
    • The screws are recessed, so a thin magnetic screwdriver aids in removal. Most bit drivers are too short to reach these screws.
  13. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 13, 1 resimden 1.
    • Lift the lower edge of the display and rotate it toward the top edge of your iMac.
    • Do not lift it too much, as the inverter cables are still attached.
  14. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 14, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 14, 2 resimden 2.
    • Disconnect both inverter cables from the inverter board.
    • These connectors are seated very tightly in their sockets. It is helpful to use your fingernails or the tip of a spudger to push the ears on either side of the connectors to dislodge them from their sockets. A small pair of hemostats helps a lot.
  15. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 15, 1 resimden 1.
    • Disconnect the two inverter cables at the top edge of the inverter using the method explained in the previous step.
  16. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 16, 1 resimden 1.
    • Rotate the display until it is nearly perpendicular to the rear case and lift it up to peel it off the EMI shield stuck to its top edge.
  17. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Bluetooth Board: adım 17, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement, Bluetooth Board: adım 17, 2 resimden 2.
    • Remove the single T10 Torx screw holding the right speaker to the logic board.
    • Lift the right speaker out of the iMac and let it hang down as you work on the Bluetooth board.
  18. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 18, 1 resimden 1.
    • Use the flat end of a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
  19. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 19, 2 resimden 1. iMac Intel 20" EMC 2105 and 2118 Bluetooth Board Replacement: adım 19, 2 resimden 2.
    • Remove the two T6 Torx screws securing the Bluetooth board to the logic board.
    • While holding the board with one hand, use the index finger of your other hand to lift the Bluetooth board up off the logic board from its left edge only.
    • Lifting the Bluetooth board from its right edge will surely cause the connector to shear off the Bluetooth board and may possibly break the socket off the logic board, resulting in a very costly repair.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 6,375
