Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw (Right side of the RAM slot on 2105)
Bu adımda kullanılan alet:Plastic Cards$2.99-
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
Lay your iMac stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
Tape the EMI shield to the face of the display to keep it out of the way.
Remove the two 5 mm T6 Torx screws securing the display data cable connector to the logic board.
Pull the display data cable connector up off the logic board by its black pull tab.
Peel back the EMI tape from the two vertical edges of the display.
Allow the lower EMI shield to hang down from the display.
Remove the four 7.5 mm T10 Torx screws securing the display to the rear case.
Lift the lower edge of the display and rotate it toward the top edge of your iMac.
Disconnect both inverter cables from the inverter board.
Disconnect the two inverter cables at the top edge of the inverter using the method explained in the previous step.
Rotate the display until it is nearly perpendicular to the rear case and lift it up to peel it off the EMI shield stuck to its top edge.
Disconnect the hard drive thermal sensor from the top edge of the logic board.
Remove the two 9.2 mm T10 Torx screws securing the hard drive bracket to the rear case.
Lift the hard drive from its left edge enough to clear the inverter and pull it toward the left edge of your iMac to unseat the mounting pins from the chassis.
Pull both the SATA power and data cable connectors away from the hard drive.
Remove the single T10 Torx screw securing the inverter board to the rear case.
Lift the inverter out of the rear case.
Disconnect the inverter cable by simultaneously squeezing the locking mechanism and pulling the connector away from its socket.
There are many steps missing--the cable is routed under the mother board. You must remove the speakers, move the hard drive fan aside, and lift the mother board to remove the long cable. This guide is incomplete!
7 farklı kişi bu kılavuzu tamamladı.
